No they told system integrators and motherboard OEMs it would work. Schenker is a reasonably well known OEM in Germany. They literally said AMD told them officially it WOULD work,and then found out the same way we all did. You seem to be ignoring this.
AMD told Schenker "though official channels". So in the end with HUB,saying motherboard OEMs have also found out at the same time. If AMD has pragmatic reasons,so does Intel despite Asus also telling us otherwise. No different.
The fact is they pulled the same stunt with the RX5600XT after OEMs had validated the cards,etc. They plonked a new BIOS just before launch,which most OEMs could actually test for it. The fact is if this is what you do for your own partners,then we are nothing in the scheme of things,as we don't have direct contact with AMD.
OTH,there are those which support later chips too. You can make selective BIOSes to target individial users.
So if a Zen3 compatible BIOS can support Zen2/Zen3,nothing stopping Zen+ to Zen3,etc and that is what some here don't realise. The package you download can selectively support specific CPUs.
But the problem is again,the reference default BIOS chip size,is mandated by AMD,so as Martini said that is really also AMD not making a more robust base specification.
Like I said both system integrators and apparently motherboard OEMs thought it was fine,so basically AMD really needs to work on its corporate communication then,because that does not bode well IMHO. Doing these sorts of last minute decisions just like their 5600XT launch,ie,all the last minute BIOSes,does not really help their cause.We always wonder why laptops and prebuilt PCs,seem to have more Intel CPUs,and Nvidia graphics cards,if this is the way they communicate things,its not entirely surprising to me.
OEM's rebranded some B450 boards B550A and they are Zen 3 compatible... i know this, i know those MAX boards would support Zen 3, how many times do i need to say that? i'm not ignoring it.
AMD are not denying Zen 3 will work with older board, we can't be sure that's true for all of them...
They have an entirely different reason for not supporting Zen 3 on older boards, officially their problem is not all of them do support Zen 3 and that creates a messy problem. If you want to tell me this is a lie you're not making a good faith argument CAT, you don't know that, this is not what OEM's said.
Edit: actually i don't know if B550A are Zen 3 compatible.
Have you actually seen the size of the chipset ? No way is it just an IO die.
