Put yourself in AMD's shoes.
You're selling a product, it requires two components to work, you only have control of one of those components, you allow the other component in older EOL form to support your product but its up to the product manufacture to enable that support and if they do its up to you the consumer to modify that product, possibly bricking it and rendering it out of warranty in order to get it to work with the component you make.
That's unacceptable...
Bios flashing a board even under warranty can void your warranty if it bricks it depending on the manufacturer. It's a risk either way.
Have you actually seen the size of the chipset ? No way is it just an IO die.
