Really appreciate the in depth reply and the link to the build, its very similar to what I want to do.
What sort of temperatures are you getting from your setup?
While I would like the system to be almost silent, I would be looking to reduce temperatures too. But if I'm honest with myself the main reason for wanting to do this is as a project.
In my setup I want to put a PE 360 in the front and a slim Magicool G2 / HW Labs 360 GTS / XSPC TX360 in the top (whichever I can get hold of soonest).
I would consider a 280GTS or similar in the front. At least then I could re use the fans I have for something. I could even perhaps use a slim 280mm rad in the top of the case which would leave more room for fittings.
Do you have any pics of your build?
