- 12 May 2011
- Southampton
Aren't those cards HOT both on the heatsink and on the rear of the card on the PCB? Are you going to add some active cooling of some kind?
It depends on what the socket can take. If it’s an early s370 designed for FPGA celerons then no there’s no point in using the socket, might as well use a slot 1 P3 (or a slocket with a s370 p3 in it). If it’s a later FCPGA socket 370 then a socket 370 p3 has faster on-die (rather then on SECC) cache.
Going to clean the freebie case up first. its a light metalllic blue/silver that screams 2000s to me. Bit minging tho.
Lets face it. The 400mhz socket 7 cant do anything the pentium3/voodoo cannot.
Also I have read a lot on here and other pages about how hot the voodoos get, should I fit a fan?
Those IDE cable headers are possibly the worst placed in history.
God that Fujitsu case is one of the most hideous things I've seen in a while, it's great!
@paradigm
I have a fan from a broken s370 cooler that I might be able to glue/screw on so will try that or order that bracket!
I love this case. I wish every case was this easy to build in.@LewisRaz Beauty! Those Acme cases really are such good quality. I love the pair of mine. I was considering moving one on as a build but couldn't bring myself too. I like how the power switch act's like the old AT style with the clunk!
