Not bad. Run default mode too.ran it but have no idea if its good or not
You need that trfc close to 300. That will get you closer to the 110 score.
ran again with default mode
So for the fun of it set trfc to about 340. That not too tight. And run again.
Your should be getting under 110 easy and 210 default.
But trfc and tfaw need to be tightened.
TRFC is how long the ram will recharge a cell for. Cells need to be continuously recharged to hold their value. Mobos put this loose as most ram of old needs a longer charge. B-die is much better in this respect.Why would the trfc be set so high for XMP when it can be tightened up so much? Tbh I'm not that up on what all the RAM timings do.
TRFC is not part of the XMP spec..so is trained by the mobo which will naturally be cautious.
Nope. That's a bit different.Ok thanks, that makes sense. So if it's being charged for a shorter time the value can be changed sooner?
Tfaw not tfawr. That should be a min of 4*trrds. Faw stands for four active window, hence the min of 4 multiplier, four read ops in the window take at most tfaw. Trrds is the time between read ops on the same bank (short) trrdl is across different banks (long) . 38 ain't bad. Maybe head to 32.god dam it i was looking for a non existent value, will have a play tomorrow any advice on what i should set it too? (default is 38)
I'll tell you how to sort it all out once I'm done playing BFV.
OK.... So what you are looking at with your timings is exactly what I was looking at when I manually overclocked my kit (which is the 3200MHz
I'm over 35 seconds faster. With cl16. Although I run 3733.@opethdisciple I don't get why I complete that test almost 20 seconds quicker than you, at 3400c14?! Your tRC should come down to at least 48. Your SCL's should go down to 2. But, can you get down to 14-14-15-14-28-42? Though I've never seen a difference in benches having tRCDWR lower than tRCDRD like it suggests. You'd likely get identical performance, and perhaps more stability at 14-15-15-14-28-42.
Have you adjusted any of the CAD_Bus settings? My system with dual rank is happy at standard 24-24-24-24 but you may be able to disable GDM if you set these to 120-24-24-24, also Proc ODT to 53 if its not already.
I've realised the dram calculator is basically a bit rubbish. Glorified spreadsheet.
I'm gonna make a wild guess.i found trfc and dropped to 340 and tfaw was dropped to 32, i've noticed since the latter was dropped the read and write speed of the ram has dropped slightly, is that normal?
