The thing is you only see large IPC boosts when the architecture is new. Especially for a ryzen - AMD wanted Ryzen out of the door ASAP to bring in money - that left a lot of places in the architecture to improve - that's what we've seen with zEn+ and zen2. Zen3 brings more tweaks. But I could also believe they are running out of big things to change. We saw this with Intel - they brought out Skylake and Intel was able to tweak some things for a couple generations and after that they had done everything they could and it's flatlined every since.
Now Zen4 May only have a small IPC gain but AMD is making another change which will really help workload performance and that's 4x SMT multi threading - so a 16 core Zen 4 shows up as 64 threads in Windows - so even if Zen 4 has no IPC gain that along will offer a good generational performance gain
I think you hit the nail on the head with your earlier assessment. Intel and AMD’s tick tock approach sounds to me like Fudge-correction. Although I would argue Zen 2 has a bit of both. Ie going from 12nm to 7nm. Zen 3 is meant to be the refinement stage thus all the previous 2 years of design flaws to be ironed out.
Zen 4 is then a new fabrication 5nm and thus new architecture. I think it will bring efficiency on Zen4 and some small IPC. It won’t be Zen5 and beyond you get the big IPC jump. Zen4 should be on DDR5 and PCIe 4 and beyond. Otherwise it will be pointless. AMD may well overlap Zen3 and Zen4 to have DDR4 and DDR5 market cap.
I just can't get my head around how you can be so oblivious to the bigger picture. Even amongst enthusiasts, there are many levels of knowledge and experience. That easily translates to all levels of expertise and computer awareness.
