Caporegime
Those speeds look identical to BT's G.fast offering, are you sure it's actually fibre to the property?
Ah good stuff, they've changed their strategy.
G.fast was just a stop-gap anyway and I'll be pleased to see the back of it as it's fairly useless unless you live on top of your cabinet.
Hopefully this brings the pricing down a little for those who can get it, although BT are already quite competitive when you've got people on 1gig connections for £50pm!
You have to contact BT. They only show their full prices on their site. Give them a call and haggle a bit. I'm paying £50 a month for my BT 1Gb connection because I haggled with them.I'm still yet to see £50pm! I keep looking and it's still showing £60pm for me as a new customer.
I'll wait for Sky to show their prices.
It worked out as £55 a month, and they credited my account with £120. Which brings the price down to £50 a month.
When I originally signed up last year, it was for their 300Mb service. Which was also showing as £59.99 a month on the site. I didn't even need to haggle, the first guy I spoke to offered it to me for £45.99 a month. Tripling my download speed and almost tripling my upload speed for less than 10% more is perfect.
I had this using Vodafone's DNS servers, noticeably faster using Cloudfare DNS on a Raspberry pi running pihole. I've always used a Netgear D7000 on the connection.
Reply from 151.101.0.81: bytes=32 time=43ms TTL=58
Reply from 151.101.0.81: bytes=32 time=93ms TTL=58
Reply from 151.101.0.81: bytes=32 time=10ms TTL=58
Reply from 151.101.0.81: bytes=32 time=70ms TTL=58
Reply from 151.101.0.81: bytes=32 time=14ms TTL=58
Reply from 151.101.0.81: bytes=32 time=23ms TTL=58
Reply from 151.101.0.81: bytes=32 time=11ms TTL=58
Reply from 151.101.0.81: bytes=32 time=16ms TTL=58
Reply from 151.101.0.81: bytes=32 time=25ms TTL=58
Reply from 151.101.0.81: bytes=32 time=9ms TTL=58
I think it's linked to the time of day. I had solid 6-7ms pings to bbc.co.uk until about 19h30, but now there's a lot of jitter and browsing is erratic:
Seems like I'm not the only one https://forum.vodafone.co.uk/t5/Int...eliable-broadband-in-the-evening/td-p/2653779
That's mine just now, can max out my 80Mbps connection even in peak times. They may have issues elsewhere in the network, I'm in central Scotland.
64 bytes from 151.101.0.81: icmp_seq=2 ttl=58 time=16.6 ms
64 bytes from 151.101.0.81: icmp_seq=3 ttl=58 time=16.5 ms
64 bytes from 151.101.0.81: icmp_seq=4 ttl=58 time=16.3 ms
64 bytes from 151.101.0.81: icmp_seq=5 ttl=58 time=16.2 ms
64 bytes from 151.101.0.81: icmp_seq=6 ttl=58 time=16.0 ms
64 bytes from 151.101.0.81: icmp_seq=7 ttl=58 time=15.7 ms
64 bytes from 151.101.0.81: icmp_seq=8 ttl=58 time=17.0 ms
64 bytes from 151.101.0.81: icmp_seq=9 ttl=58 time=16.7 ms
64 bytes from 151.101.0.81: icmp_seq=10 ttl=58 time=16.3 ms
64 bytes from 151.101.0.81: icmp_seq=11 ttl=58 time=17.4 ms
64 bytes from 151.101.0.81: icmp_seq=12 ttl=58 time=18.0 ms
64 bytes from 151.101.0.81: icmp_seq=13 ttl=58 time=16.5 ms
64 bytes from 151.101.0.81: icmp_seq=14 ttl=58 time=16.5 ms
64 bytes from 151.101.0.81: icmp_seq=15 ttl=58 time=16.0 ms
I've just had an Openreach engineer turn up to see if I minded them doing the outside work for my FTTP installation today in advance of the rest of the installation on 9th June. Fine with me.
I assumed that they were using pre-terminated fibre from the CBT to house, but no, as I write this he's measuring a length of fibre from a spool to run through the duct under my front garden.
No need for conduit loads of room going to just use some clips. You can kneel up there is that much space.They won't crawl under floors, but they will have no issue giving you a fibre to pull under there yourself. Though I'd probably run conduit in advance and leave a draw string in place.
