It's called the PS5 and XBox Series X, isn't it?![]()
Sort of i suppose, talking more along the lines of 3900x and 2080ti on the same die. The heat output would make comet lake look like a damp squib.
FWIW, I reckon RDNA2 will ray trace a lot better than Turing, yet won't match Ampere, but AMD's implementation of ray tracing will be more refined reducing rendering bottlenecks and just tip overall performance over Ampere just a tad. Although it's been discussed the rendering workloads on Ampere are significantly more balanced now.
But why? They did it with Ryzen. Jumping from Faildozer and its derivatives into Zen 1 literally jumped them right up into Intel's face out of the blue.I'd like to see that too.
But it's an big ask though with RDNA2 being AMD's first generation implementation of RT.
Realistically I cannot see them out performing Nvidia's new upcoming range.
I think it would take something real special like an dual GPU die card to make up the deficit that they are lagging behind by imho.
Wonder how long it'll be before an apu makes a GPU redundant for even the high end, can't really see it in the short term as the heat output would be mental.
Of which would've happened already if RDNA1 had scaled up like it was supposed to. Right now I'll be more surprised if AMD's deficit remains as big as it is. But then, AMD actually having a "deficit" is a discussion in itself (excluding Vega, of course@LePhuronn
I guess we will see.
All I'm saying is AMD has to cross an huge performance void from the 5700XT if it's going to get anywhere near the new 3080(ti).
)I'm really happy with AMD now which is more than what I could've said previously.... Ryzen is fantastic, look at the 3900x in which will be paired with a higher end gpu which will typically be gaming at 1440p/4K and it'll offer virtually the same performance as Intel whilst offering much better multi threaded performance for less money. RDNA1 is a good indication as what's to come and AMD don't need to exceed or match 3080 Ti performance. If they can offer 80% of the performance for 60% - 50% of the price £550-£600 which should be £50-£100 cheaper than the 3080 ( whilst matching it ) will be excellent
that's a long long way from 'pulling a Ryzen in the GPU market' unfortunately
Ryzen wasn't perfect as well, far from it. If AMD equals or comes close to the nVIDIA offerings at a very good price, will be something.
My best guess is AMD's top RDNA2 card will probably end up being around 10% faster than the 2080ti (aka the Nvidia killer, current gen) while costing say somewhere around the £600 to £700ish mark.
All-in-all that would not be an horrible result for AMD, as that is still some strong performance for the price.
But that would mean AMD is battling it out at the low end of the Nvidia product stack again (the 3060, 3070) rather than the top.
But that's just my opinion, as I said above I would love to be proven wrong.
Seeing Lisa Su walk out on stage wearing a full black leather jacket and just stand there with a cheeky little smirk on her face would be priceless lol.
.costing say somewhere around the £600 to £700ish mark.
It never will, surely.Wonder how long it'll be before an apu makes a GPU redundant for even the high end, can't really see it in the short term as the heat output would be mental.
Define "decent ray tracing". If you want your ray tracing at the same time as 100+ FPS @ 1440p then I'm not sure even big Ampere can do that. Ray tracing alone on Ampere is suggested to be 4 times better (to the point where the 3060 should ray trace as well as a 2080 Ti), so things are certainly getting there, and DLSS 3.0 is supposedly damn good in design, implementation and the entire product stack has a boat load of Tensor cores to run it for an extra kick.Wondering what it will cost for 100+FPS @1440p with decent ray tracing? I'm being that will be high end and not a lot of change from a grand.
I don't see AMD being light years behind, but I'd be surprised if they come out first time with Ampere-equivalent RT performance.
If that's all AMD are bringing from their top RDNA2 card they might as well forget it. 2080ti+10% performance at £600-£700 in 2020 isn't going to work. It sounds acceptable but I think AMD needs 2080ti +20%My best guess is AMD's top RDNA2 card will probably end up being around 10% faster than the 2080ti (aka the Nvidia killer, current gen) while costing say somewhere around the £600 to £700ish mark.
