- 2 Mar 2012
x570 works with zen 3 doesn't it? just needs a bios update when it comes? might start buying some parts soon...
New "leak"
RYZEN 9 3900XT - 4.1GHz base, 4.8GHz boost
RYZEN 7 3800XT - 4.2GHz base, 4.7GHz boost
RYZEN 5 3600XT - 4.0GHz base, 4.7GHz boost
Oh well for the time 3900xt to take the top AMD gaming CPU crown again, we had a good but short run, 3950x
Here is a comparison of the new XT models vs the regular Ryzen 3000 CPU's.
The main part is going to be the 3600XT (if naming is correct) in terms of volume, value and difference. The R5 3600 was the one to get, not the 3600X due to the small difference in performance, but with the XT at ~£199 and a much higher boost, and better base clocks then the XT part becomes a much more convincing argument.
The 3700X at the new low cost should also be attractive to people in the ~£239 bracket who want more cores/threads, and not the extra speed, but there are weird things going on with the 3800X pricing as well, so where will that end up if the XT version is priced at ~£299 to compete with the 10600K/10700.
If they stick to the release date, then it will be a year to the day since the 3000 series launched.
300mhz increase on base clocks for the 3900X is pretty good.
Bragging rights4.7Ghz for a few seconds isn't much good to anyone,really.
I don't see how +200Mhz is going to make any difference
What's the clock speed of the 3800X in game?
The 3600 is 4.1 to 4.2.
Looks like this refresh is not just a simple core clock boost.
Infinity fabric speed is up rated too, sitting at 2000mhz on the FCLK, so you can now game with 4000mhz memory on your 4.8ghz 3900XT
AMD seems to be intent on taking Intel's gaming crown without even having to use Zen3 lmao
