- 12 May 2011
- Southampton
I don't suppose anyone has any plastic stand offs they're willing the share / swap for something?
the slidey ones (like in LGRs Making a 486 video) because I have a hole in the motherboard but not the PC case. They don't seem to exist on eBay UK but I can get some from the US for about £12.
40 minutes left on that rusty crate load of what look like IBM 5150s and 286 machines... Still at £56.
I can probably 3dprint some and send you a couple. Assuming you can find a 3d Model of something useful?the slidey ones (like in LGRs Making a 486 video) because I have a hole in the motherboard but not the PC case. They don't seem to exist on eBay UK but I can get some from the US for about £12.
Yes and Yes. The material has quite a bit of elasticity and yes I can work with AutoCAD files (or an export as .OBJ, .STL or .DAE).Thanks for the offer, I'll have a look around to see if I can find a model. Does it work from AutoCAD files because I could make one probably. Is the 3D print material a bit elastic so a pin will squish through the motherboard hole and then expand out again?
Some of those cards have RTCs and batteries on. I could look past the rust but I think the real shocks are going to be inside!I do wonder what cards are inside though? Any RAM cards or video cards that might be with a look?
Its an odd one,, it could be valuable if someone with the ways and means gets it. But its pickup only and the pics are terrible.Unsold at £122. I wonder what the reserve was and how much backroom "bidding" will go down!
Sure, I’ll trust you.@paradigm Could I trouble you for the STL you used on those Shuttle feet a few pages back please?
@randal Decided it was easier to just put it on my webserver: https://www.paradigital.net/ocuk/retrostuff/shuttle-foot.zip. You'll want to set it to 22mm wide rather than the 38mm it's at now before you slice it.
So if your Shuttle is different to the pics, what did you get? Mine is exactly as per the pics (probably is the one from the pics).
