@randal are you able to repair the bits that you got?
Not had a chance to check yet, been setting up a new PFSense instance for dual WAN for most of the afternoon.
Hey, I'm interested to hear about your pfsense setup. Physical or Virtual? I'm going to be building a pfsense box next week based around a i3 6100t. Just waiting on the case to arrive!
My edge router lite is not about to handle 100mbps with QOS on virgin and always wanted to have a go with pfsense!
Link? I’ve got the rework gear and the time!Boxed Voodoo II found in a house clearance ending soon on eBay, not tested but might be worth the risk, may go cheap.
Was going to bid but do not have the time / potential gear to start removing memory chips.
Sempron 2700 and 256MB out, Athlon64 X2 5000+ and 4GB XM2 in.
Pics needed tbh. Interested in the condition of yours and the 3d printed 2.5” adapter!The Shuttle is up and running, well at least the hardware is. Managed to bend the CPU pins back into place, and by some freak chance the DDR2 survived the trip through the post in a payslip envelope.Sempron 2700 and 256MB out, Athlon64 X2 5000+ and 4GB XM2 in.
3D printed a 2x 2.5" HDD bay adaptor, ran another SATA cable and installed a couple of drives ready for an XP installation and Lewis's AMD X1650.
Inside is utterly filthy though, IPA'd as much as I could but I think the board will need to come out for a toothbrushing at some point. Still, more than happy with how the build is going and really looking forward to booting up some classics soon.![]()
