Hi All
I’m new to the forums and could use some input, please.
I’m in two minds about ordering the X570 Tomahawk.
I’ve got a TX650M PSU, an AMD 3300X and 16gigs of Crucial 3200CL16 E-Die as a start. Haven’t decided on a GPU yet (probably an AMD 5700).
I want to get a Panteks P400A as a chassis with a view to upgrade to a Zen 3 CPU next year.
I could get a B450 motherboard which would suffice but I’d actually like to play it safe and get a B550 or a X570 board.
The X570 Tomahawk is a bit out of my budget at £218 but it’s quality. Should I just bite the bullet and get it?
I have a sneaky suspicion that Zen 3 is going to be very power hungry at the high end of the product stack, so the board partners are using far bigger capacitors.It was out of my original planned budget I also have the 3300x and a basic 5500xt so yes its massively overkill. But I could easily say I could get 10 years out of, 4.6>8>12>16 core (upgrade cpu every 2 years).. never know we might even see higher core variants on the 4000 series. the basic gpu as no fancy monitor yet so roll on big navi
June 16th, I think?When are these B550 boards being released?
June 16th, I think?
The BPL is supposed to start on the 17th so good things are happening mid June.
I'm very interested in getting ahold of this motherboard to upgrade my existing system and put in a Ryzen 9 3900x and Seagate Firecuda PCIe 4.0 HDD. Although I've not decided on which cooler to upgrade to should I need it during the summer, do we know if the motherboard will have the clearance space for air coolers like the Noctua NH-D15 Chromax ?
Thank you!
I own the d15 and I've already ordered the board. So I'm hoping so as soon as its here I'll let you know but I'm sure it will as I currently have the noctua cooler on this mortar max.
is this a possibility?I can't get free shipping yet![]()
was my post subtle enough to say "WE NEED AN UPADATE?" lolHaha yes. I feel this. Are we there yet?
