What's the attraction of the Ubiquiti EU Store? Seen it mentioned many times, but the prices seem better/on-par at a site for Broadband Buyers I've used for 15+ years.
Stock. They have stock.
It wouldn’t be Youtube though if they just chucked up a few nano HD’s though would it?
I have two Ethernet cables running through my house. One in the second bedroom the other in the conservatory.
Is this a 4 bed house with stud walls, or solid walls?For reference I have a single nanoHD mounted on my landing ceiling which covers a 4 bed house. It’s the same as a flexHD, just a different form factor more suited to being mounted on a ceiling.
Hi Guys,
I'm abit of a network newbie. I'm trying my best to understand what I want and what I need which has landed me with Ubiquiti.
Im struggling to get a signal to my nest security cam at the back of my house. We have a decent sized 2 bed semi so I dont need to go crazy with a full on mesh system ( I dont think). Im with Virgin Media 350mb package with the superhub 3 which doesnt feel stable.
Here's a link to my floor plan.I have two Ethernet cables running through my house. One in the second bedroom the other in the conservatory.
Without anyones advice, I was thinking of putting my virgin super hub 3 into modem mode and buy a AmpliFi HD Mesh Router. Then using the ethernet cable that is in the conservatory with a UniFi AC Lite. Upstair the wifi seems fine so probably stick with my Ethernet splitter.
This comes to ~£220.00
Is this the setup you guys would recommend?
House was build 1905 - solid brick walls, when i refurbished I put 55mm insulating plasterboard on all outer walls which hasnt helped.How old is the house and what's its construction? I'm in a 3 year old house and had to put APs in the eaves to get a good signal for my Nest cameras outdoors. Until then the external walls of the house were blocking the majority of the signal and the cameras constantly went offline.
Hi Guys,
