Did anyone get 2 of the magnetic filters? I have 2 and im sure on the reviews ive read it only came with 1?
Pretty sure he said one at the bottom (the third one) was not magnetic. Nothing about there only being one magnetic.Did anyone get 2 of the magnetic filters? I have 2 and im sure on the reviews ive read it only came with 1?
What boards should I pair with this case guys (B450/550) Just got it delivered and I remembered it's A-RGB. So does RGB still work with it?
The RGB works independently of the motherboard via remote (and / or reset button if you want)
It can be plugged into and controlled by the motherboard if you prefer via either the ARGB or VDG connectors.
I need assistance with ARGB and the MSI b450 boards with this case. What will I need to get the ARGB working with MSI B450 GAMING PRO CARBON AC? Will the argb hub work with this board?
Yes, that board has 1 x 5v argb header, plug the hub into that and you should be good using MSI's Mystic Light software to control it.
Does anyone know where i can find the online manual for the Gamemax Kamikaze pro? i'm thinking of getting one to put my new system in (this cosmos 2 is just too big), but i can not find the online manual anywhere
AIO arrived today, really easy to install. (Before and after):
Temps look really good, currently sitting at 24 degrees idle and all I can hear is the case fans.![]()
Is that the ARCTIC Liquid Freezer II 240 AIO?thinking of doing a similar thing. Is it acting as an exhaust?
