The archangel gives you only slightly more range (5%), but the ADS time is slower. Depends how you play really. It has better iron sights but I find it too slow for me.
[Archangel] +4 frames ADS +45% range -3.5% movement speed
[Nexus] +2 frames ADS +40% range -3% movement speed
I use nexus, monolithic suppressor, commando grip, 60 mag, void grip
Thanks, I might give it a try but I also like the fast ADS, your loadout is the same as mine. I think I prefer the Grau now to the M13. I never got on with the M4 as much, maybe I never got the setup right.
