Caporegime
- 18 Oct 2002
Nooooooooooooooooooooo @LoadsaMoney you're gonna make someone bring out the 290 Jet Engine Edition vid
All signs pointing towards a big fat old % increase in price again...
Right we'll remember what you said when they turn out to be like a GTX 480!![]()
So one example means AMD = inefficient and Nvidia = power?
YES!!!!!!!!!! Come on nVidia, you know you want to crack that £2k mark....![]()
Nooooooooooooooooooooo @LoadsaMoney you're gonna make someone bring out the 290 Jet Engine Edition vid![]()
Already did that. Titan V and RTX Titan.
Yup, my 290X's sounded *just* like that![]()
You are saying no AMD cards are efficient? You sound like you know things everyone else doesn't.
The 5700XT is actually slightly more efficient at the same clock than the 2070 Super in performance and power is essentially the same.
It's certainly a revolutionary designed cooler matched with a revolutionary PCB no doubt
With a node advantage and a smaller die. 5700xt has a similar PPW to the old 16nm 1080ti
FYI for anyone reading this, black is both a good absorber and emitter of heat. It depends on the use case.If they powder coated alu then they are noobs. It would totally kill all of the heat dissipation, even more so in black (which absorbs heat). It would need to be anodised. Which is probably what it will be.
You don't need to, just concentrate on the howling inconsistencies.
I don't think they are fake. I just think they are 3d printed for testing purposes.
It's irrelevant how they get to it, they are still there.
How so? If your main competitor is more efficient with less and sooner. Then when you competitors do start using 7nm like you .......
Mainstream.
A new node was available to AMD, they used it. Nvidia can start using it too sure, but at the point of competing with the AMD 7nm product they weren't so how is it relevant that they could start using it a year or 2 later?
AMD have stated a 50% efficiency uplift from RDNA1 to RDNA2, but that's completely irrelevant in the comparison we have with actual products that are on the market too.
