Lian Li O11D- Mini....(latest post with AIO Up top in ATX format)
Latest update is now early September according to replies on their Facebook post.
Not sure if I should wait or not. If I have to drop something like £150 on an SFX PSU, that might make me change my mind too.
Currently swinging towards Corsair 280X instead, or maybe just put up with the larger 011D. Not that anything is in stock anyway!
Nice find.
The youtubers who saw the case earlier in the year, all said it used a SFX PSU. I don't expect that to change.
New update. Now due October :(
Alaina @PCWorld pinned a comment on the following video
Her info from this video is great though and is worth a watch. Should allow me to get motherboard ahead of time which will fit in with the watercooling setup I want.
Cant hardly wait for that case, ive got everything at the ready to go in it, just might need a thicker radiator to help deal with the heat as i'll only be able to get 1 in it.
It also requires an SFX PSU guys, doesnt take a full ATX PSU.
Took a gamble on a new mATX board, so that's paid off. Already got a 280mm rad, will look to pick up 2x360s.
Hopefully we can pre-order soon!
They didn't say anything about SFX during the latest video. Hopefully it will fit ATX.
I know he didnt mention it, but it was mentioned in all other videos, and have a look at the size of the other chamber when he's showing you around the case, its tiny.......as in thin, theres no way you're getting an ATX PSU in there
According to the spec on Lian Li there's going to be extra motherboard backplates for swapping adapting to your system built, I don't know if I'm reading it right.
Model O11 DYNAMIC SPACE GREY SPECIAL EDITION – Chrome Mirror Finish
DIMENSIONS (W) 272 x (H) 446 x (D) 445 mm
MOTHERBOARD E-ATX/ATX/M-ATX/Mini-ITX
PSU 2, (L)210mm~255mm (max)
COLOR Space grey
MATERIAL (Front) Tempered Glass + Aluminum (Side) Tempered Glass (Body) 1.0mm SECC
FAN SUPPORTR (Top) 120mm x 3/140mm x 2 (Optional) (Side) 120mm x 3 (Optional) (Bottom) 120mm x 3 (Optional)
RADIATOR SUPPORT 120 x 360mm/120 x 240mm/140 x 280mm
GPU LENGTH length ≤420mm, height ≤159mm
CPU HEIGHT ≤155mm
DRIVES 4 X 2.5” SSD + 2 X 3.5” HDD
EXPANSION SLOTS 8
IO PORTS USB3.0 x 2 USB3.1 Type-C x 1 HD Audio
DUST FILTERS (Top) x1, (Side) x 2, (Bottom) x 1
COLOR Space grey
CPU HEIGHT ≤155mm
EXPANSION SLOTS 8
Wrong case, that's the O11 dynamic with the mirror finish, the mini is going to factor for different motherboard sizes by changing the back panel, but it's not going to make the space bigger for the PSU
Yep, as above. CES 2020 back in January showed these as needing an SFX PSU, unsure if that was SFX-L too. I think that will remain as Jamin surmised. But I remain hopeful there is enough space back there for ATX too. I'd much prefer SFX and not have issues with tall GPUs. Especially as this is for water cooling, some water blocks are tall with their inlets/outlets.
Hurry up and let me pre-order this already, Lian-li & OCUK!
Lian Li confirmed SFX and SFX-L on Facebook. So have ordered a SF750 in antcipation.
Latest is late August pre-order. Probably mid Sept delivery.
