- 2 Aug 2016
I hope it supports 280mm rad
Nice find.Latest update is now early September according to replies on their Facebook post.
Not sure if I should wait or not. If I have to drop something like £150 on an SFX PSU, that might make me change my mind too.
Currently swinging towards Corsair 280X instead, or maybe just put up with the larger 011D. Not that anything is in stock anyway!
They didn't say anything about SFX during the latest video. Hopefully it will fit ATX.
Supposedly towards the end of August 2020 and priced at $99.99 USD... I'm definitely getting this case.Was gonna buy the standard dynamic one but this will look much better on my desk. Any idea on release date?
According to the spec on Lian Li there's going to be extra motherboard backplates for swapping adapting to your system built, I don't know if I'm reading it right.I know he didnt mention it, but it was mentioned in all other videos, and have a look at the size of the other chamber when he's showing you around the case, its tiny.......as in thin, theres no way you're getting an ATX PSU in there
Model O11 DYNAMIC SPACE GREY SPECIAL EDITION – Chrome Mirror Finish
DIMENSIONS (W) 272 x (H) 446 x (D) 445 mm
MOTHERBOARD E-ATX/ATX/M-ATX/Mini-ITX
PSU 2, (L)210mm~255mm (max)
COLOR Space grey
MATERIAL (Front) Tempered Glass + Aluminum (Side) Tempered Glass (Body) 1.0mm SECC
FAN SUPPORTR (Top) 120mm x 3/140mm x 2 (Optional) (Side) 120mm x 3 (Optional) (Bottom) 120mm x 3 (Optional)
RADIATOR SUPPORT 120 x 360mm/120 x 240mm/140 x 280mm
GPU LENGTH length ≤420mm, height ≤159mm
CPU HEIGHT ≤155mm
DRIVES 4 X 2.5” SSD + 2 X 3.5” HDD
EXPANSION SLOTS 8
IO PORTS USB3.0 x 2 USB3.1 Type-C x 1 HD Audio
DUST FILTERS (Top) x1, (Side) x 2, (Bottom) x 1
Hope the cables are long enough, I had to buy longer ones for mine in the case i'm using.Lian Li confirmed SFX and SFX-L on Facebook. So have ordered a SF750 in antcipation.
Latest is late August pre-order. Probably mid Sept delivery.
