So, the other half bought me a Build-it-yourself P Bass kit from Thomann and I'm already enjoying doing work on it, even if it is just minor stuff!
Decided to style it after an early 60s Fender, so going for shell pink with a tort pickguard. Not sure what material the fretboard is on these kits, but I was very unimpressed when looking at it initially. Turns out it was still filthy, give it a quick wipe off just to see properly and it looks like ebony (although it clearly isn't) with a very nice grain pattern. Body has no real grain, assuming it's basswood due to how light it is too.
Neck pocket is a lovely snug fit, but none of the pickguard or tuner screw holes that have been drilled are in the right place! First job, toothpicks and wood glue
. In honesty, the bridge and neck are spot on so that's the important bit. Getting a replacement pickguard anyway that'll likely have holes slightly different to the kit one, so no issues filling and re-drilling them now before any sanding or painting.
