- 25 Mar 2004
- Fareham
I only have a 60Mbps connection so probably wouldn't notice if devices were dropping onto 2.GHz, a quick check of the connected devices does show everything I'd expect to be using 5GHz connected on that band, though. The only thing I have trouble with is the Fire TV Stick moving to 2.4GHz if I reboot the Hub, which presumably is related to it creating its own ad-hoc Wi-Fi network when it loses the one it's meant to be connecting to. Rebooting the Fire Stick always fixes it.
Meanwhile every single one of my devices is using 2.4Ghz!
I am currently trialling 900Mbps fibre, so it's definitely a big drop in performance for the wifi connected devices.
Router is under the stairs in a cupboard but not that far away, 2.4Ghz is meant to be better for signal but less so for speed.
