G73SW replacement screen is around £100 on ebay. Motherboard can be had for around £60.
Nearly every laptop I have repaired myself have been relatively easy to fix, and parts are often pretty easy to replace. More often than not the hardest part is getting into it in the first place as some require most of the thing to be in pieces before you can get to it's guts.
This is what your motherboard should look like if its rev 2.0, you can see the cmos battery on the left side.
No, thats NOT ONE bit like my Motherboard.
As I said, the base system Is indeed a G73SW however while EVERYWHERE I looked said the CMOS at the bottom and the battery etc etc etc... Mine had no battery like this, and it had no way to reset the CMOS.
I did ask ASUS for a diagram and I looked for one elsewhere and I could NOT find one for my specific motherboard.
I can for this and yes I have seen that very board, but my board is NOT that one. My board does not even remotely look anything like that. Mine has 4 RAM slots, the SD Card reader comes out on the side on that one, mine comes out at the front. As I said previously, I can get bits for the G73SW easy as pie, but for some annoying reason, mine does NOT seem to be the standard.
I know cos I have been inside it more times than the wife.
And no, there is no battery like in the picture and so thats why I thought it could be an axial cap type but nothing was obvious.
Please believe me when Isay that I have tried... I would not have sent it off if I hadnt have tried.
As for the screens, I have bought one but it did NOT fit. it did not even remotely get even close to fitting.
At the time, the cheapest screen that WAS the same as mine, was £450
I have been looking since and I found a couple at just over £290 but the others ARE NOT THE SAME AS MINE WAS. Again, I bought one and its sat here doing nothing cos it does not fit in the case, even though its a G73SW screen.
