Thanks both of you for the info. I haven't played many MMOs so that is good to know. I do get the logic behind the wipes but was just making sure. Like you say I guess I should wait for release then , which may be some time.There will be no progress carried over from beta to release as is standard practice in any MMO, so I would suggest launch is when you jump in if you're not happy with wipes happening before. In any event 'launch' is a while off.
Or wait until betaThanks both of you for the info. I haven't played many MMOs so that is good to know. I do get the logic behind the wipes but was just making sure. Like you say I guess I should wait for release then , which may be some time.
Or wait until beta
Wow the game work's on Linux!
So no better than running in windows thenBit crashy though, can play for hours sometimes then other times it will crash in 5 mins multiple times.
We need a proper client and Vulkan![]()
So no better than running in windows then![]()
Yeah, We can now say linux gaming is the same as windows![]()
Absolute nonsense that pal.
You don't get spied on when using nix unlike Windows![]()
crashing out
its been out since 2016This out yet?
And it still ain’t hit Beta yetits been out since 2016
Idris?Here is a leak of a jumble of corridors....
Idris?
The thumbnail image literally says "Aegis Javelin Ship Tour".Idris?
