i have always hated the heat i would rather be cold and add clothes than be hot and want to rip my skin off lol
You’ll turn the rest of the property into an oven quite quickly. Also with the door open, it’ll start to suck hot air back into the room so it’ll be fighting against itself. It’ll feel cooler sat in front of the machine but you’ll lose a huge amount of efficiency.
Moisture shouldn’t be a huge issue, the machines I’ve used collect it and need draining from a plug.
Mine has a flat pipe go for a much higher BTU to compensateQuestion. Can you get a mobile air con unit with a 'flat pipe' at the end of the exhaust tube and shove it out the door of the bedroom?
A friend can't get split unit due to council restrictions on outdoors things. Also can't touch the windows to get a pipe out.
A few things I note:
1.) Even a flat pipe tube is quite thick, the door would still have quite a gap meaning loss of cooling
2.) It would still make the room cooler
3.) Considerations around moisture coming out of the pipe, it would need to have some kind of bucket beneath it perhaps?
Sorry just the end is flat had it on three times so far also have a window seal but a ghetto mod is fine for me for nowAs in the whole pipe is flat or just the end? DO you do a similar thing to what I described? As in shove it out the door?
civilised temperatures
