- 26 May 2018
- Bewdley, UK
Yeah that’s a good one too
Thanks just the memory to go then the wait begins.
Getting the B550 isn't a bad call IMO, the VRM's on those board are a lot beefier then what you typically find a B450. How much did all that set you back in the end?
Looks fab. I’ve just finished my build in the NZXT 510 case you originally listed in your spec (although I went for the i version).
Really surprised at how cheap the case feels for the price. Have used a number of cases in the past, most recently a BeQuiet Dark but the NZXT feels cheap and thumb screws are awful, so glad you went a different route.
How’s the noise level on the BeQuiet Shadow Rock 3? I’m currently using the stock AMD cooler but it’s got an annoying whine on the silent mode so will be upgrading it sooner than I had hoped.
What made you choose the 3600 over the 3700X? The latter would have been a better choice IMO particularly with next gen consoles.
It's also double the price, the gains don't out weigh the price here imo.
Correct I got the 3600 for £142 I think on offer.![]()
Nice for a first time build mate - that BeQuiet cooler is a behemoth!![]()
Thanks took me ages about 4 hours but I took my time. Certainly is a beast! Seems to be doing a great job on temps so far.
Looks good, glad you managed to get it sorted. Just make sure it is on the first floor so when you get flooded this winter you can still use it.![]()
Oh dear have you had flood issues? I'm not by the river luckily. Not lived here that long really from Worcester originally so know all about rivers.
Luckily no, but I know many who have.
Hope you are enjoying the PC, I'm busy building one for someone local who bought all the bits, then failed miserably at trying to put it together, not quite as bad as a 'Verge' attempt but pretty shocking nonetheless.![]()
