- 17 Sep 2006
- Gloucestershire
Get an Ant+ dongle and use that (if you can obviously). Much more reliable than BT
Haha I wondered where this post had gone!
Good shout, how much was the 970?
Rubbish, think it's something unique to your setup? Any searches for support seem to point towards their Facebook community pages but I don't see any responses from them on there. Just wonder if worth posting and others may chime in, else try and contact RGT as there could be something obvious/known they'll throw back your way.Urgh... Have practically given up on RGT because of its clunky Bluetooth sync issues. Thought it was working last night (resistance work steadily increasing through a warmup) and then it baulked at the first 500W interval, reading 180W and complaining at me.
HAha and so it should on that setup! Although good point, I think I've got an old R9 280 or similar which works just it's missing a heatsink. Could then throw that into the Q6660 I have with 6GB ram. Anyone running it on Windows 7? Think that's the only windows retail licence I have spare. This has to be a no/low cost project as else I'll just spend £150 on a 4K AppleTV and have no setup/install times and issues. Except of course wanting to use ANT+ and not BT but meh.Not been on zwift for a while but I run it on my desktop. An old R9 290, fx 5350 six core and 16gb ram and it runs sweet at 1680x1050.
Weird, everything else ok - other sensors drop too or just trainer? Worth checking firmware and any updates for it. Also switch it to BT/ANT+ whichever it's curently not on and try it. Think most people find switching trainers to ANT+ and everything else on BT generally irons out any signal issues?I’ve had a couple of power drops from the trainer recently. Like one every 5 hours of riding. Resistance doesn’t change, just no power displayed on Zwift, comes back after 3-5 seconds. I’ve always been free riding luckily, but not sure why it does it as I’ve changed nothing.
I have HR and Trainer on ANT+ so good suggestion.
But I’m not sure my computer does Bluetooth, I’m using the older Tickr, is this one Bluetooth as well? My Garmin is Ant+ only.
Using windows 7 here Roady, no problems.
Mine has been far more stable since I did this, but have still seen the occasional 'bad' day/night on it. Still not utterly convinced that quite a lot of my problems where not server side as usually other people also reported issues the same events/days.2 other lads on my team done exactly this and echo exactly the same as me. Zero drops since.
My TICKR is 5-6 years old and does both BT and ANT+.I’m using the older Tickr, is this one Bluetooth as well? My Garmin is Ant+ only.
Partly why I've turned into quite a Zwift supporter. It has it's moments and they really don't help themselves with messing with the engine/features but the whole 'just generally works' thing is huge for me as a time pressured 'I never get to ride enough' individual. There's a lot else to go wrong with signals, equipment and all the different setups people have, never-mind a flaky/unstable engine and servers...I suppose the main irritation is that - as I only use these systems for interval training that lasts 15-30 minutes - Zwift just works, whereas RGT requires I spend almost 20-30% of my workout futzing about with the phone... All the while having to pedal because the Bushido is self-powered!![]()
Haha nice, what was the session?Race at the end & this lady just disappeared up the volcano climb, almost 6wkg! I was in the main group managing about 4.5-5w (7 min power PR for me on the trainer up the climb).
Yeah, she's a beast. I'd heard the name and knew she was good but didn't realise. Looks like her Zwift isn't attached to Strava (where she rides under her other halfs name),so can't see her data from it.
51kg, CAT A & Former National Hill climb champ in 2016, so quite good at hills!
She's taken gold in both the Turbocharged womens rides so far...
Within 10w of my FTP but almost 30kg lighter!
Nice! Absolutely great finish and some fantastic numbers there! I do like the Volcanos ramps, really does get me riding hard the few times I've raced it. I like the corkscrew too! Although looks like you do too... 1.5 minutes faster up there than me lolTotally wiped, hardly able to pedal or do anything! Peak 1 minute power record for me of 6.4w/kg, probably went up into the volcano at 5-5.5, lifted to 4-4.5 Momentarily then opened out for the last 600m. It took a good 10-15 mins to feel back to normal. Check Strava, max HR 201, last minute at over 190 ah yes that explains it.
For me, I’d have to have 10-15 mins at least to get warmed up ahead of an effort like that and a few leg/lung openers first.
Otherwise I just wouldn’t be able to try to do the set.
Seems like a “life hack” type workout.
Perhaps if you just want to maintain a fitness level of X then it will work, but for actual cycling forget it. I can’t imagine it’s particularly nice trying to do the efforts, and if you then don’t see an improvement the motivation to keep doing them is going to be low.
