@stument
That is all kinds of awesome!!!! Brilliant image.
Love it! The tank itself is surprisingly stable.
I like this. Almost looks like a scene from a computer game.
Thanks! That's the kind of vibe I had in mind when taking it and processing the raw image![]()
I take it that's your car and you stepped out to take the photo? What f stop, shutter speed and iso settings did you use? Teach me, I'm a beginner
NiceI take it that's your car and you stepped out to take the photo? What f stop, shutter speed and iso settings did you use? Teach me, I'm a beginner
That's an awesome explanation, thanks! Yes the light flares look very cool. I can see how much nicer it is after removing the yellow cast. I've got a circular polariser which I've never used yet. I guess using that in the evening would have increased your shutter speed and iso? Wow though, 3.2 seconds, you must have set up a tripod? Is it possible for me to get a similar composition with everything in view like in your shot using my 50mm f1.8 lens at f8, and how would I change an edited raw image to 16:9? is that something you do within lightroom or photoshop, or are we just talking simple cropping along the bottom?
If you're on full frame then there's not actually much difference, as m43 is 2x crop factor. 40mm on yours will be the same FoV as 20mm on mine!Thanks, yes, I kind of thought I'd have to stand further away to get the same since you were on 20mm and I'd be on 50mm. Mine is a full frame, 5d mk2.
Wow, that's a stunning car photo! Love the passenger side gloss and wheel sharpness.
