- 12 Jul 2020
Really hoping the stock arrival Wednesday means they'll be shipped out Thursday, otherwise it's going to be a pain on Friday as I'm out of office lol.
Where are you finding that information? HDR and Gsync work together on my 32". I know Freesync 2 supports the newer AMD specific low latency HDR (that Assassins Creed Odyssey has implemented) but normal HDR does work with Gsync.I posted that above, HDR does not work with Freesync it needs Freesync 2 and G-Sync Compatible is based on the former for now.
Ive seen some people have issues with certain monitors only supporting HDR over HDMI, or a few monitors not letting the user enable Adaptive once HDR is enabled (a couple Acers) but thats a monitor restriction. I'm coming across far more results of people using Gsync Compatible monitors with HDR successfullythough and I just googled "hdr g sync compatible" Gsync ultimate is also a totally different ballgame to Gsync compatible so doesnt really compare.I have the monitor and it is also widely known, and now Nvidia do G-Sync Ultimate is for G-Sync+HDR (newer hardware module on 4k models).
Google it and see people using a trick to try to get HDR (in some form) on G-Sync Comp screens while adaptive Sync is enabled (they use a Acer Tool, does not matter if monitor is another brand).
STAND is around 800mm wide by 300mm deepDo we know how big the G9 stand is front to back? Trying to work out if it will fit on my desk/shelf.
Too deep by 20mm!STAND is around 800mm wide by 300mm deep
Too deep by 20mm!
(32" G7 ordered on the 19th of June)
