After spending forever reading reviews of almost every case possible, I am drawn to the 011 Dynamic XL. I'm looking for some advice on how best to transfer my build to this case.
I currently have a Gigabyte Aorus 1080Ti, 3700X CPU and X570 Aorus Elite motherboard. I have a Noctua NH-D15 chromax black as the CPU cooler.
I heard the CPU cooler might be a really tight fit. I don't want to risk damaging the glass somehow, so I'm tempted to switch to an AIO cooler. Bonus would be a nicer looking internals.
So I'm thinking I will get:
- Corsair H115i RGB Platinum / iCUE-RGB / 280mm
- 6x Corsair QL120 / iCUE-RGB / PWM / 120mm
Does that sound sufficient to cool everything well? Open to suggestions or change of components. I thought I'd stick with Corsair for everything just to make it easier to set up the RGB lighting.
Not sure if I should go with the Corsair iCUE H150i RGB PRO XT / 360mm for better cooling, but at the cost of no RGB. Which may or may not be an issue.
