Is that a factory or custom colour?
Standard colour. Cosmic blue.
Acme is correct! It is Cosmic Blue, equal in my blue love to Fords Imperial Blue.
Not had the car all week while it’s been detailed. Had a decent amount of work done
- 2 stage correction
- Crystal Serum ceramic coating with 2 coats of Exo on top
- All external glass coated with Carbon Collective Platinum glass
- Wheels off and coated with Carbon Collective Wheel Coating
- Arches coated
- Engine bay full clean and coatings where appropriate
- Leather treated and coated with GTechniq leather protection
It looks absolutely phenomenal. So chuffed with it. Almost a shame to drive it and get it dirty
pics
Did I miss something? When did you get an AMV8??A shot of the Aston & Honda together, need to erect a third garage and am also redoing garage interiors to make them smart on inside but for now got the outside looking how I wanted in slate grey.
You're way over.Can't have had much change out of £1500 I'm guessing?
How much did the paintwork protection part of that cost? And how long is the treatment supposed to last with regular washing?
I will eventually need to look into it when I've had my car resprayed.![]()
You're way over.
I'd put a coating at about £250.
If you're having your car resprayed I'd expect to pay around £600-£800 as it'll need a single stage, wipe down and coating.
It is a very small car by modern standards. Less surface area than a new Mini.Pretty much every detailer will sort your interior and wheels in a package. I could dig out my invoice but yeah if it was £1500 I hope he got a 3 course meal and a kiss before the deed was done.He said a 2 stage correction, and then a coating, and then some other kind of coating, and then the wheel thing, the arch thing, interior stuff, engine bay stuff, etc.
600 would be good.It is a very small car by modern standards. Less surface area than a new Mini.
Ah i think I remember now. Difficult to keep up with your constant car purchasesQuite a while now but I very rarely drive it. The M5 and S2000 see the most use, followed by the 458 and Abarth, Aston is once a month at most.
I paid £750, which is a bit cheaper than it normally would be but I’m friends with the guy so I get a smallish discount.
In terms of Gyeon vs GTecnhniq, Gyeon are superior for nearly all their products, and he uses their products for a lot of things. But their coatings are still pretty poor in comparison so he’s still not using those yet
Smart! How much did the garage spraying cost?A shot of the Aston & Honda together, need to erect a third garage and am also redoing garage interiors to make them smart on inside but for now got the outside looking how I wanted in slate grey.
