A question from someone who knows no more than I have read in this thread!
I have been thinking about what set-up would work in our house - and for the bedrooms (well 2x bedrooms, 1x home office) where I would want the aircon, the external walls are difficult because of either being very visible from outside, or having built in stuff in the way.
Does such a product exist as an aircon system where the internal end is in the loft, with ducting to take the air into the rooms via the ceiling? I was thinking this would avoid having to have pumped condensate, as the piping would only have to go down from that main unit.
If such a thing does exist, does it limit the individual control between those three rooms? And is is significantly more expensive?
You have ceiling concealed units which as you mentioned can be ducted to the rooms, but you (sorry to state the obvious) need return air grills in the in the room.
You can have them for individual rooms and install would be more expensive.
https://www.saturnsales.co.uk/Slim-Duct-Range.html
 still pulling 800 Watts though.
