Is anyone planning on using the side bracket to mount AIO rad? Seems air cooling is dominating the builds right now, and although I could go down that route I've got a Corsair H115i Platinum that I'd prefer to re-use from my current build if possible (I'm assuming it fits).
If I have to go down that route I will, but I really want to be able to see the mobo through the glass panel not the side of a rad
From an SFF perspective, it's just really poorly designed. Long, stiff tubes which exit from the top of the block, with no rotation = nightmare. Couple that with an iffy warranty, and it's probably best avoided.
