Have you been drinking from the same kool-aid as the Nissan executive that said EV chargers are too heavy for women to use?
In all seriousness since when did 60 make someone too weak and frail to manipulate something that is akin to a hose pipe...
The lock is generally controlled with the central locking key fob. E.g.
car locked = cable locked
Car charging (regardless of locked or unlocked) = cable locked
Car unlocked = cable unlocked
The process normally goes, press button to unlock car, pull out cable.
No, it just passes 240v to the car and the car converts it to DC using its onboard charger.
