Had that a few times on my journey so far and yes it has crashed or will do shortly, it should almost immediately turn into a progress bar and flash up details of each file it's downloading, before it inexplicably stops and throws you back to the desktop. I'm currently making more progress than I have previously which I think is down to disabling Bit defender, there was nothing in the logs saying it had blocked anything but I disabled it anyhow and so far so good.I'm on a screen with a blue loading bar at the bottom, with literally no idea if it's crashed or installing!![]()
t1600m can be switched to left handedAnyone know of a left handed HOTAS, I have tried to search but only found one where you can separate the joystick and throttle but then the throttle has buttons on the right hand side which is no good if your right hand is on it
Thrustmaster TCA Officer pack is the only one I can think of that will work with both handsAnyone know of a left handed HOTAS, I have tried to search but only found one where you can separate the joystick and throttle but then the throttle has buttons on the right hand side which is no good if your right hand is on it
In Windows settings apps select it and there's a repair option I think, not at my machine but there may be a cache option as well, you could try that, might fix it
I have Cyborg Evo and had no problem with mapping but you need to select it otherwise it will not detect imput. There is section saying assigned, you change to all and then select from listNo major issues for me here either.
But sadly got a problem getting the joystick to work. I've got a Cyborg X (waiting for the new Airbus stick to ship next month) and it detects it, but doesn't map any of the buttons. There doesn't appear to be an way to click and button and tell you what ID tag it is to map the feature such as brakes.
It looks like you can save presets, so i don't suppose anyone here uses a Cyborg X, or been successful in mapping an older stick?
Thanks
ta it suddenly decided it was missing content and told me to restart
Thanks
Up and running and playing, however had a nasty issue with excess drift on my Xbox 1 controller that works perfectly fine on all other games.
It was basically applying very slight right steering on the left hand pad causing constant rolling to the right that I'd have to amend. Couldn't even fly straight.
Luckily found a fix, just go to Controls, then Select Controller, then the Sensitivity box on the left. I changed the X axis from the default 0 deadzone to 50, and it flies perfectly straight now with barely any adjustment needed.
Likely will work just as fine with 25% or less deadzone, but 0% deadzone on a Xbox 1 controller L stick X axis was damn near unusable - and that's the default setting. Just a head's up.
