Why tho? The 970 was £370 something and the 1070 was £400 ish.id go for a 3070 for £500-550. Anymore and ill either wait or see was Radeon have to offer
Why are so many prepared to just up their spend?
The 970 also dropped a fair amount in price, I bought mine new for £230, 1070, 2070 never came near thatWhy tho? The 970 was £370 something and the 1070 was £400 ish.
poor state of the 5700XT with drivers at launch
$1399 for the 3900 rumour just hit redgamingtech.. he seems to jump on anything though tbh.
Many like every gen cannot get their head around the fact price for performance improves over time. Turing has made things worse. I still remember here many did not believe that 980Ti performance could be had for under £400 and then the 1070 came outWhy tho? The 970 was £370 something and the 1070 was £400 ish.
You are willingly running an unsupported and unpatched OS
I'm sure 970 was £270 on launch not £370, the 980 was around £400Why tho? The 970 was £370 something and the 1070 was £400 ish.
You have absolutely no point to prove, no security consultant would agree with you about using an outdated, unpatched and unsupported OS, so it's best if we don't continue to the conversation and just agree to disagree instead of get into circular arguments (which are my pet hate as far as forums are concerned).And as if to prove my point...
https://krebsonsecurity.com/2020/08/microsoft-put-off-fixing-zero-day-for-2-years/
Is that really any different to running an unsupported and unpatched OS if they take 2 years to fix security issues that are being actively exploited![]()
You are right that in some areas of computing price does improve as performance progresses, CPU's are a great example of this. However, GPU's are being used to fleece people as part of a multi-billion dollar gaming industry. They know people will pay. It's that simple.Many like every gen cannot get their head around the fact price for performance improves over time. Turing has made things worse. I still remember here many did not believe that 980Ti performance could be had for under £400 and then the 1070 came out![]()
Agree about what? I never advocated for using Windows 7 - I'm just having a chuckle at getting on a high horse about people still being on 7 and extolling the virtues of Windows 10 on the merits of being patched and supported when there is stuff like that coming out about it all the time and any security professional worth their salt would have concerns about how many of these issues should never have existed in the first place. There are probably more important or higher security issues patched in 10 this month than the total that have been patched and ever will exist unpatched in Windows 7 - that isn't ignoring that if a big exploit is found in Windows 7 it is less likely to get fixed in future and there are limited ongoing programs to find and patch any existing holes.
I don't disagree with your point about Windows 7 being old and unsupported but Windows 10 simply isn't covering itself in glory on this front - and I'm honestly surprised people aren't as up in arms about it as they are with the Intel CPU security situation because it is no less concerning and potentially more so.
Now please, lets stop flogging a dead horse, agree to disagree on anything we don't see eye to eye in, and get back to the grim reality of the GPU hype train.
- Windows 10 is patched and supported and represents the safest consumer version of Windows currently available. Fact.
- Windows 10 is not perfect and still has security flaws uncovered on a regular basis, some of which are serious. No-one said otherwise. Fact
- There is no perfect or bulletproof solution when dealing with an operating system of such breadth and scope. Fact.
- If you want to run Windows OS then one should be realistic and pragmatic and take the best option of Windows available to them. That option is Windows 10. Fact.
980ti zotac was right at the beginning for £499 at OCUK. So you saved £100 and now this means you'll save £600?Many like every gen cannot get their head around the fact price for performance improves over time. Turing has made things worse. I still remember here many did not believe that 980Ti performance could be had for under £400 and then the 1070 came out![]()
So you are saying 3070 will be £1000 or more?980ti zotac was right at the beginning for £499 at OCUK. So you saved £100 and now this means you'll save £600?![]()
No sir, price for performance always improves
AMD have been out the game so long at the high end GPU level that honestly think they would struggle to convince people to pay £700 for "3080Ti" perf. They may have to run a loss first gen back just to get their name back out there again.AMD can't charge much if anything over £750 imo, they just don't have the incredible mindshare that nVidia has so you should be ok...
By the sounds of it the 3090 will probably cost 2 grand, which is utterly, utterly insane.
https://www.guru3d.com/news-story/rumor-geforce-rtx-3090-pricing-to-sit-at-2000.html
I don't feel any safer on my Windows 10 machines than my Windows 7 ones which probably don't even have 100 security issues in total![]()
