My Xigmatek Elysium could swallow two of those puny 3090s whole!not sure on the spacing on the mobo but if the 900D can’t take the physical size of the 3090 then pretty much everyone will be needing a new case![]()
I'm interested to see what happens with regards to "reference PCBs".
In the past, the founders edition has usually served to provide the "reference PCB" design. Whilst some third parties then design their own boards, the reference provides a baseline which will have the most support for things like waterblocks.
This time round, it looks like the founders edition is going to have a weird shaped PCB (with the 'chevron' cutout at the end) and the new 12-pin power connectors, whereas most aftermarket cards are far more likely to stick with a rectangular PCB and 8-pin power connectors for ease of manufacture and maximum compatibility.
This raises the question of what will the "reference PCB" be? It can't really be the founders one as hardly any other manufacturer will use it. Are NVidia going to provide a separate "reference" PCB to third-parties to function as the standard?
I’m just worried, as my 2080 Tis are already quite close in my mobo, and the bottom one runs really hot.
Its almost as big as mine that
Also looks a bit fake
Time for a loop
who said water cooling is dead
maybe the tensor cores? mGPU seems unlikely imho due to the complexities of support though arguably Hopper will need to fix that dunno its possible I guess but hard to believe atmI still suspect the RTX3090 is a dual GPU or has another chip which needs cooling. The size increase over the leaked RTX3080 cards is noticeable.
Supposedly the new GDDR6x has thermal issues, running at something around 97 degrees, which has added a lot of extra heat to the Ampere designs.
You would have thought that the way forward is small, not big...
To infinity and beyond!
Not really when you see most people that buy a high end GPU pick the ones with the biggest coolersYou would have thought that the way forward is small, not big...
From Guru.
I am not skilled enough for that!![]()
