Saddles are so personal but I love my Fabric Scoops.
Yeah of course, just keen to know if there are any good considerations at a reasonable price, this looks like it might be one of them!
and I cannot stand them....
Nobody can rightfully suggest a saddle out of thin air for you and any decent saddle worth having will cost the pennies I am afraid.
I ride Fizik saddles. Arione R1's and Antares R1 Versus Evo. I don't particularly get on with any of them.
Have tried Fabric Scoop's and an S Works Power recently. Didn't get on with neither of them and these were both loaned from people who will never ever change away from those as they love them so much.
So that's a proper mix of different shapes, lengths and styles of saddle (all top tier full carbon expensive jobs also!) to show you that it is the most personal/differing thing between people and their bikes.
Oh I get that, trust me! Although think the bike it a clear deep red enough to get away with wearing orange!![]()
Agreed! But with a red/orange bike, both red and orange are kinda odd to wear with it![]()
Yup, general buckles and such. Even a broken spoke (well broken nipples) or two. But it can be a very frustrating and thankless task when you first start... I'd say start on an old wheel and spend some time either removing a buckle, or even creating one (take a nipple off) and then trying to remove it. Key is to take your time, do it in really minor/tiny amounts and really really gradually when starting. It's too easy to overtighten a wheel and you'll just end up 'chasing' the buckle around the rim making things far far worse... A spoke tensionmeter is handy, but I've found it more of a 'troubleshooting' tool than any help when removing a buckle (use it to find a slacker spoke without a buckle present).Anyone has any luck learning to true their own wheels? Just conscious that our local bike shop won't be able to fix for 2-3 weeks!
Chainring bolts are a b*ch to get, especially 'branded' ones. Ask a LBS and they'll usually give you one, or buy a set of 5, just make sure you get stainless ones and don't bother with the shimano 'peg' type ones (although don't think they're a thing anymore on the newer cranksets - they're a PITA as you need a special tool to hold them). I ended up with some 'raceface' anodised black steel ones after trying various junk lesser branded ones which just seemed to be cheap alloy and would either strip when trying to get them tight (or not go tight enough), or aluminium which would corrode and be impossible to remove. Last I looked the Specialized branded ones where stupid money, even Rotor ones are over £20. I think the Raceface ones I got are £6 on the rainforest.Went to change it today and realised one of the chainring bolts is toast. Availability for the bolts looks a bit poor online. Emailed the LBS before I make a journey down to find out they have none. Probably should have just stumped up for a chainset but I heard the newer R7000/R8000 chainsets aren't typically compatible with the 6800 FD. Can't see why not but didn't want to risk it.
Quality advice, but if you're utterly tone deaf like me you'll have to find other ways of doing it! I could generally tell by 'feel' when some of my spokes where getting slacker than others (I went through a phase of breaking nipples on Giant rims). I've not had to do it for a while now so may not be as easy the next time...Replacing a spoke is easy enough. Change it out, make sure the crosses with other spokes match up. Tighten it up, 'ping' it with your finger every so often, and compare the ping to other spokes on the same side. Once it's about right proceed as for wheel truing
Have to agree, kinda why the Rapha Core have become so important to me! They're only £85 too, fantastic shorts for the money. I couldn't feel enough difference to the £195 pro team, but I do like the Brevet (£180) although not for more than double the cost...I’m not convinced that £200 bib shorts offer any improvement over £100-125 ones.
It will soon be bib tight weather if it stops raining!
That was my first thought! Also not a fan of silver. Actually quite impressed with the little cheapy Topeak Roadie DA I bought. Although it does have a really short throw as it's double action you can just go mad on it without worrying too much about bending the pump. The Dual Action is good and I was able to put probably 100PSI into a 28mm tyre in around 2-3 mins without having to really strain against the pressure (but probably 100+ pumps!). Was impressed how tight I got it the first time - actually had to release some pressure!Just make sure the hose isn’t going to rattle and rub your paint/frame away!
This is not something we currently have in stock, and looking at the UK supplier it is currently on back order with them. They are currently quoting a date of 20/11/2020 for delivery. Would you like me to place an order for you, or do you maybe want to have a look at alternatives?
I saw a set of unused R8000 rings go for £40 posted on the 'bay over the weekend. Although unsure if they came with the Shimano special bolt covers and chainring bolts... Just a FYI.
Chainring bolt supply issues... Asked LBS.
I guess that UK supplier is Madison. Crazy. Is there an aftermarket option?
Edit: Missed your response, Roady.
What do you mean by Shimano special bolt covers? Not seen covers unless you're using non Shimano rings on shimano chainset.
Yup. I went through so many Fizik's too and kinda settled on the Arione (before they did the VS and Open versions), I'd never gone for wider saddles or cutouts. Then new bike came with a wider saddle with cutout and it was comparable 'comfort' without much bedding in... After getting used to it supremely more comfortable. So then trying a few more cutout saddles (when I needed one for turbo) and couldn't get used to the same saddle on the turbo. Just ruined me, yet absolutely fine when out on the road. Switched to Specialized Power and it was on par (even though quite different), then when it came for a new saddle on the outside bike also switched that to a Power. Think I've now found the perfect saddle for me, at least until the next time!that it is the most personal/differing thing between people and their bikes.
Define 'reasonable' price - remember it's the most 'personal' and important interface between you and the bike!Yeah of course, just keen to know if there are any good considerations at a reasonable price, this looks like it might be one of them!
Many LBS who do fitting will have 'test' saddles they may let you borrow/hire (example).I did see an s-works power on marketplace going for a good price, and was tempted! I dont really have many local cycling friends to borrow or try bits from, so thats out of the question for me!
See below. Although if you can get the actual bolt out, then unlikely you need the cover as don't they just pop off?What do you mean by Shimano special bolt covers? Not seen covers unless you're using non Shimano rings on shimano chainset.
Yeah that's what I was thinking, after putting mine together those bolt covers are quite specific/unique. Although those seem to be to use smaller chainrings on the general 4 arm cranksets due to the spacing.these ? https://www.wiggle.co.uk/ta-ultegra...okizir80Bn1t56uSFOQybpVVvgBIrW_BoCw6IQAvD_BwE
cant find the start of this convo in the thread so this might be barking up the wrong tree.
(Of which I have one of each...)and I cannot stand them....
https://www.rosebikes.co.uk/shimano...c-6800fc-r9000fc-r9100-and-xtr-fc-m970-681749
Rose have them with 2 weeks leadtime, but they're just an M8x10mm so you can google that and get a ton of results if it's just the bolts you need... These look like the Raceface ones I ended up with (but that wasn't on Shimano 4-arm, so I needed both 'sides'). These 5800 should fit but you'll have to do some checking/research to confirm they didn't change pitch/bolt sizes (unlikely being Shimano).
There are no covers to pop off on my chainset. I think that's literally for using non standard chainrings with Shimano crank spiders. I just have bare bolts.
You're correct, apologies I was getting muddled with the Powertap C1 I had which had similar...! Just had a look at my bare R8000 and it's just bolts into the crankset with no 'reverse'.There are no covers to pop off on my chainset. I think that's literally for using non standard chainrings with Shimano crank spiders. I just have bare bolts.
Said it before, will say it again... Something you push into your bum crack for hours on end is a deeply personal matter....
Yep - those are the ones. I saw them available from multiple German shops like bike24 but the thing is postage and packaging adds up to £10 to the already fairly extortionate price. I might as well return the chainring I got and order a new chainset if I'm going to spend £20 on bolts.Is it Shimano Ultegra Double 6800 11 Spd Chainset lethal ? that's the same as mine, i thought mine did have covers, haven't got bike to hand, but just zoomed in on the picture i posted of my bike on here and it would appear they don't.
would it be these bad boys ? https://www.bike24.com/p2145931.html
R8000 manual has them listed as M8x10 so the ones I linked on Rose, the ones from bike24 or anything like these would be compatible (coloured!). Providing you can get the stuck one out... Is it rounded? Mine are star nuts not hex's.
EDIT: interesting read I just found. Everesting... Everest!![]()
