That’s a brilliant idea, let’s all be positive![]()
The more do it, the more NV may worry and say something.
Lets overclock it https://twitter.com/nvidiageforceuk?lang=en
Say things like "Super pumped"
It'll also serve well to heat your room in the autumn and winter period!
Just saw a post saying that each Ampere GPU will need a total of 247 6 pin adapters to power it, making a grand total or 1254 2.5 pins needed? That can't be right.
.I don't understand, 8pin supplies 150W and 6pin supplies 75 right? Is it just a prototype with a couple of bodged-on 6pins because they didn't have an 8 lying around?
When do we expect these to be in stock do you reckon?
Based on past experience they'll be rarer than hen's teeth for a good few months yet while preorders are honoured. Then prices will go through the roof due to lack of supply. Finally about March next year things will start to settle down.
My silverstone FT02 Case can take
Prepare for the "trickle" feed of stock and the buy now because we can't guarantee these "low" prices for much longer.When do we expect these to be in stock do you reckon? I'll buy either a 3070 or 3080 depending on performance / price ratioNew build needed for FS2020
Also.
From what I have understood the pic leaked the other day of the supposed 3090 (this one)
snip
Is not fake. Rather, they put an Intel chip over the card to hide something. Now we can see that is the back of the PCB, so they may be hiding this new co processor. However, you can also see it has 3 8 pin. Not two, 3.
That is because that leak was of a Colorful card in China. That is not the FE.
Going back to the 12 pin connector. Two 8 pin are not enough. They can not supply enough current. I guess on Seasonic they are confident that two 8 pin connectors on their power supplies! is enough. However DO NOTE. Those 8 pin connectors are not PCIE connectors they are Seasonic PSU "end" connectors and will most probably be wired very differently to other PSUs. As such you may well find that the after market "fits all" adapter will be 3 8 pin to the 12 pin to cover all scenarios.
Two 8 pin can not supply 600w. That is why the 2080Ti Kingpin, HOF, Aorus and etc (IE all of the ones that can be voltage unlocked) have 3 8 pin.
you know it!Followed by a lower price a little later saying we managed to secure a very good deal or found a bunch in our warehouse somewhere. LolPrepare for the "trickle" feed of stock and the buy now because we can't guarantee these "low" prices for much longer.
It has a shroud on both sides, the rear one only has fins over what would be this supposed RT co-processor: https://videocardz.com/newz/nvidia-geforce-rtx-3090-graphics-card-picturedIf they are going to have a processor on the back they will need a heat sink for it. Assuming it is true it would be interesting to see how they plan on cooling this.
