- 24 Aug 2020
thank you Saibork, but the question is on a ITX Mainboard
Apologies, i'm new here. I have edited my post to remove the link. thanks for letting me know.Also just so you know you can't mention competitors or any website that might link or affiliate with competitors so you might want to remove your link
I just noticed that it also links to an older version of the NH12. But if you look at the NH-U12S page it lists the space and dimensions, so it depends on what motherboard you pick/use on whether it would fit. Of course also on what memory you'd pick.thank you Saibork, but the question is on a ITX Mainboard![]()
Noctua NF-A12x15 Chromax are in, can't link an image from Imgur for some reason, fans are amazing quality compared to the arctics but they have the typical buzzy noctua sound that I don't like. they don't seem to make much difference than having no intakes to the temps after a quick heaven run temps seem the same but will check again
interesting
what cpu cooler are you using?
That said, I don't see anything where this is mounted in 90 degree turned fashion. I think you may not even be able to do it because of the was the cooler is screwed into the motherboard.
the ultimate orientation!Test Revision build: Arctic liquid II Freezer 240mm AIO & Vertical GPU
CPU idle Temp 39/44c / GPU 39c
Along way to go yet, just did a quick build Revision
Anyone done a build with the raijintek morpheus GPU cooler? Looks like it should just fit?
Also what was the conclusion with the Noctua nh-u12s. Will it fit with TG panel? If not surely a small amount of the heat sink material could be removed
