The weight was standard as FS set it at and I was flying over France crossing into Switzerland.
Also what I mean the plan isn't level with the horizon the the screen it's constantly pointing up which is slowing the plan down, like it's trying to climb even when it was above the altitude hold.
Surely the process of ascent is the same as 10-20 as it is at 35-45k?
It's also worth considering that the default airliners are absolute garbage, in particular the autopilots are extremely buggy. If you want anything close to realism you're going to need third party add-ons which are a while away yet.
Normal airliners in flight will typically sit from 2-3º nose up in level flight, so don't be drawn into thinking you must be level with the horizon at 0º for level flight
