Caporegime
- 18 Oct 2002
If these initial cards are all 8nm Samsung I'd say it'd def be worth waiting for the refreshed range in a year on 7nm TSMC. Time will tell all!
That's exactly what it is, they're shovelling coal on like there's no tommorow. That's why the card is so huge with a totally new design fan and is triple slot.
If this was AMD's forthcoming top card it would be getting memed to **** on power usage and size.
If you took a 1080Ti and you ran the same game at 4k and you utilised DLSS the 2080Ti will absolutely mangle the 1080Ti. DLSS is the best thing to happen in years, and it happened first on Turing.
If AMD's top card runs away with the performance crown regardless of power and size, I doubt it would be getting meme'd.
For the wacky-shaped FE PCB which no third party is going to use,
Course it is mate. Goddamn AND ruining everything again for NV customers...(shakes fist)
Apart from the power connection, I don't think the PCB is going to be a wacky shape; rather I think it's the cooler that is unusual.
Well, the 2080TI was £1200, Nvidia are not going to do 50% more for 20% less, but 50% more for just 20% more seems like a bargin, right?
The Nvidia video on youtube shows the PCB shape
Not sure if seriousI watched it and nothing sprang out about the PCB.
Does anyone have an inkling on likely availability timings for these?
If the announcement is 1st September, are we looking at Founders edition available October, then manufacturer AIBs in November?
. Time will indeed tell i guess
You upgrading? If they price the 3070 something stupid like $599 like crazy people keep suggesting then maybe I will buy your 2070SI reckon reveal on the 1st, available the 21st, with customs coming 28th, what i'll be waiting for, another Gaming X-Trio with a bit of luck.![]()
I had the exact same issue with farcry 2 with the microstutters especially when i went xfire. It did scale nicely but the microstutter really put me off so ended up selling one. I remember picking up 5870 top tier card at the time for as little as £200 brand new!!!
