Ah fair enough, that was my main concern (basing all this on vertical mounting btw) that blowing all that hot air onto the board where your chipset is, m.2 slots are etc might cause long term heat damage. In particular AMD X570 boards with the small fan on the chipset.It also depends on just how hot the air is, i mentioned before that an open air cooler like triple fan dumps all the heat into the case, this is using the same kind of fans (axial) but configured so one is an exhaust and only one fan is putting warm air into the case. So overall it's not going to put as much heat into your case. I think this was tested on LTT and the difference between blower fans and open air was around 5c tops, so not as much as you would think.
Thermals should be interesting...
Sign me up for a 3090.
I have to work out if it’ll fit inside a Corsair 540!
That is going to suck for mini-ITX systems!
Also,I hope people have decent CPU cooling,that hot air is being dumped right onto the motherboard!
What a thing to put on a backplate... do these companies not have designers?
I’ve got a Corsair 750D with three exhaust fans pulling hot air straight out the top of the case.
As far as I can tell the heat from a 3090 FE would literally be blown right out the top of the case rather than cooking the CPU. Will have to wait for reviews for more info though I guess.
Would think if you’ve a case with top mounted exhausts it shouldn’t really be a problem.
Haha fair playSave you one.... I may work for GIGABYTE but trust me, I'm at the front on the queue... Cyberpunk and Knight city here I come.....
Is this only on the 3090? I wonder if they are trying to passively cool the memory chips on the back.The Palit has something similar:
Actually it's normal for them to act as insulators, IIRC it was the reference GTX980s that dropped like 5-10c when you removed them.Pretty standard for a card with a backplate working as a heatsink.
Prices can change guys, either way remember that, it is very early days and pricing is yet to finalised by many board partners.
OcUK will aim to have largest range online and the very best prices with plenty of stock coming in.![]()
Backplates are normally included to support the card and stop it bending over time.
If already posted, sorry![]()
A few generations back I recall a time where gpus were released and there was disparity between cuda cores between skus. Later on Nvidia filled those skus with Ti variants leaving those who bought 1070, for example, to buy 1070 ti just to get the performance they should have had from the beginning. So I created this chart to keep track of this.Interesting theory. However, i don't see how this make sense for Nvidia. Assuming "later on" is less than 6 months
