Caporegime
- 9 Nov 2009
- Planet Earth
Maybe they haven't had their last Rollo??That's harsh, definite troll post.![]()
I certainly think RTX 2080 +80% for the RTX 3080 is very selective absolute best case, this is where Nvidia's marketing department builds too much hype and not for the first time, the RTX 2000 series was also massively over hyped performance by Nvidia.
The 2080 ended up being little better than the 1080TI, remember that?
FOr £449 I will defo buy it. Perfect 1440p gaming rig.
I can run F1 2018 at 1440p good quality with Radeon RX 560X, that is Polaris 11/21 with 1024 shaders, 4GB GDDR5 128-bit memory interface and 123 mm² die size.![]()
Not very though he had/has videos covering most angles - he claimed a bunch of new feature technologies that at best are tenuously similar to actual new tech in Ampere, his initial claim was his reliable source apparently claimed TSMC 7nm would be used for the 3080/3090 (I can't remember what produce numbers he used but basically pointing at those tiers) and Samsung 8nm for the lower end cards, then that changed to TSMC 7nm through the stack then eventually Samsung 8nm, etc.
EDIT: His "full" leak and IMO what he should be judged on as it presents some degree of exclusivity whereas the later information that is more correct is posted after the fact when other reliable sources have covered it: https://www.youtube.com/watch?v=oCPufeQmFJk
Top end GA102 card would be 220w, 2.2GHz clock, 864GB/s memory bandwidth, 5376 cores, built on TSMC 7nm, come with DLSS 3.0.
I'll leave the audience to decide.
Fair play to them, they milked it for a while. Who do you blame though, nvidia for taking the cream, or the punters for queuing up and shouting "take my money!"?
I'm glad to finally get a performance leak of some kind. It would be something to consider if I were thinking about the 3070.
Many of us are considering the 3080 though, and they get released in less than a week. Maybe AMD will leak something that's relevant to that....before the 17th might be a good idea.
Well the 3080 FE review embargo has been pushed back to the 16th... Make of that what you will
https://mobile.twitter.com/aschilling/status/1304531723456335874
https://wccftech.com/amd-next-gen-radeon-rx-6000-series-rdna-2-graphics-cards-benchmarks-leak/
Ayyyythis better This lil Navi ??
So they made a mistake ^^^^ ?
Lets hope AMD can improve their marketing and market position like they have in CPU's if only to stop giving people like this constant ammunition.
He's got one of them awful accents that drones on too much like a lot of americans, seems like they need their nasal passages bored out. Not as bad as Gamer Meld though, that's toe curling bad.
Can't have the punters knowing what they're buying before they splash the cash, that would be sheer madness![]()
it will probably OC like crazy tho...https://wccftech.com/amd-next-gen-radeon-rx-6000-series-rdna-2-graphics-cards-benchmarks-leak/
