It follows reference design for power phases which is 13+3 (same for MSI Ventus). The FE is a custom card with better than reference design using 15+3 phases.
That's the only difference and AIB partners likely didn't know what the FE would look like anyway. They just tiered their products from reference as base and then upwards.
