- 13 Jun 2016
- UK
I'll take a look, taYes. There was another post in the graphics card section. Bloke who got his card on launch day had a block on it by about 10pm
https://forums.overclockers.co.uk/t...waterblock-to-it-and-overclocked-it.18899105/I'll take a look, ta![]()
@Jay85 Gives me an opportunity to finally muster up the courage to git my waterblock to my 1080Ti! Having never fitted a GPU waterblock, something about it is making me nervous as I don't want to brick a 1080Ti FTW3! I guess the reality is that it's no more difficult than building a PC or the rest of the custom loop, but something about it is making me a bit nervous!
Makes it sound far more complicated than it actually is. I've done several blocks over the years and never struggled to line things up. They pretty much self locate.The trickiest thing is always lowering the block onto the card trying to align with all the holes at once, so as not to come at it skew whiff and catch the capacitors on the block, or have to lift off multiple times to adjust, with the consequent mess it will make of the thermal compound. This is what I do to make this a piece of ****.
Cut up some cotton buds so you just have a length of the plastic stalk, you want one for each screw hole on the block. Lay the block on a surface with the copper side up. Wedge the plastic stalks into each screw hole and make them as vertical as possible. Cotton buds are ideal cos they are usually just the right diameter to wedge in the holes and stay there. This now gives you a guide to gently lower the card onto the block via the holes in the card, and it should self-align as it goes. You then just pull the buds out and screw together. I would do a dry run first without any paste so you get the hang of the method. You may also need to have something to raise the block off the surface so the pci bracket on the card has somewhere to go when the card is lowered onto the block, or overhang that part of the block over the edge of your desk, the dry run will help sort out the little issues. For the actual run, paste up the card as required, and depending on how sticky the heatpads are you may need to put them on the block rather than the card. This is what I do and have never had a problem with getting a block onto a card.
Yeah please mate if you have time, would love an in depth look at the block to see if it will suit my needs. Manufacturer pictures always make it look better than it actually is. Let us know when you get it and also what the quality is like. Distance between the inlet and outlet etc and dimensions would be great.Just had notification that my Alphacool block has been dispatched. It still shows pre-order on the site though.
I spoke to Alphacool on their facebook page, they said retailers would be getting more stock in about a week. Either that has come in early, or they actually have stock they're not showing.
If you want some detailed photos putting up when i get it, then let me know. I wont have a card to install in on though.
Sorry, I feel a bit harsh now. It's a good tip if you struggle, thanks for the suggestion. But hopefully it won't be needed.Not what is hard about cutting up some cotton buds to help anyone trying to overcome the apprehension of losing their virginity on their first gpu block, but whatever.
Haha, the little black plastic tubes? I used to pop a bit of thermal paste on them to hold them in place.Who remembers moveable standoffs before they were routinely milled into the blocks. Now you're talking fiddly!
I held them with pure will power, always worksHaha, the little black plastic tubes? I used to pop a bit of thermal paste on them to hold them in place.
This is exactly me lol, this is proven to work and has done for many yearsAh yes forgot the thermal paste holding method, I did later use that after reading about it.before it was 'you shall not move' while waving index and middle finger held together in front of the standoffs
Can relate, seems headroom is minimal hoping a good card (FTW3) to will let me capitalise on my loop.In the end, I've got Strix on preorder and block for it on preorder from EK. It's more than I expected to pay but I think it might be more fun to play with more powerful card. I don't want to just watercool itI hope there will be some tweaking left for this combo.
Even TUF is impressive already to me, 60C for this power hungry card? Brilliant imo.Can relate, seems headroom is minimal hoping a good card (FTW3) to will let me capitalise on my loop.
I think it's a triple slot cooler though it might be quite impressive on air?!
