Official Zotac rep underfire on Reddit with regards to the 1 - 3 % lower performance..
2 May 2020
The weak fan curve - that can be improved easily yourself.
It down clocking more aggressively than the FE at 70c + - that can be improved by bios or mitigated by the user applying a custom fan profile.
The lower power limit than the FE - that can be improved by bios BUT the pcb may have components that cannot cope with the increased power.
Thanks for clearing this up mate
27 Sep 2006
My Zotac arrived today. That tiny FPS drop is more than made up for by the quadrupling of my frame rate @ 1440p with high settings in Apex during the three months that I would otherwise have to wait to benefit from upgrading my 980ti.
If you've got a decent card already no harm in sitting it out for a bit, otherwise it's just a matter of getting whatever you can. I had my eye on the MSI Gaming Trio X, but when Gibbo posted the stock just before launch I grabbed the Zotac instead.
Hopefully they release some BIOS updates but if they don't I won't lose any sleep over it. I'm happy to sacrifice a couple of frames for a quieter card anyway. As for the PCB, it works, and it's got a 5 year warranty. If you want to push the clocks, then you wouldn't have ordered this card in the first place.
25 Aug 2011
I'm in two minds about cancelling mine, something doesn't sit right with paying basically £50 over RRP for a lower performing card. Using that calc I'm 26 in the queue.
2 May 2020
Great to hear you have yours.
8 Sep 2003
150 yds from OcUK
my Zotac card just arrived..... what to do now...????
1 Dec 2015
The 5 year warranty was the main selling point for these cards. Everybody else has 2 or 3 years.
The very slightly slower clocks wont make any real difference.
18 Sep 2020
Mine is coming tomorrow aswell, 14:01 order time.
I'm not bothered about the 1 to 2% fps loss.. As for the PCB surely the card can't be completely crap if it has a 5 year Warranty?
I don't Overclock much at all.. Maybe a tiny OC. I usually undervolt though if performance isn't affected
Never actually paid attention to a PCB before, I thought they were all the same. Every gpu I've had in the past were all gigabyte (HD 7950s, R9 290X, RX 480 GTX 1070, RX 5700 XT.
I just wanted the warranty for some reason lol
