- 13 Sep 2005
Is there a mini guide for the cheapest way of getting ultimate (which will also cover PC)? Something about upgrading gold membership time? Thanks.
Stolen from another kind member.
Buy up to 3 years of Xbox Gold either UK or Brazil to get it even cheaper from cdkeys.
If using the Brazil codes, connect to a VPN with a server in Brazil and check your IP location shows you as being in that country.
Go to microsoft.com/redeem in an incognito window to avoid any saved logins, login to your MS account and redeem the live codes, do not accept the free month for renewing if you want to add 3 years as it will take you over the max 36 months.
Log out, turn VPN off and then either use the xbox app or website to use the £1 upgrade offer. If you have already had a game pass sub you can buy a 1 month Ultimate code from CD Keys for £8.99 and just add that on the xbox app. It will say you are buying 1 month of ultimate but if you check your subscriptions after it will be prepaid until however months of Gold you had.
It's only when you add Gold to an Ultimate sub that you get the rubbish conversion and existing customers with an expired gamepass sub can do the same thing but they might not have the £1 offer so just use a 1 month prepaid code instead.
