- 25 Apr 2012
- Oxford
I used surf shark! Sign up, claim codes then cancel
CDKeys has my purchase as 'under review'. Great.
Happened to me the first time, was fine the next morning.
Hopefully can sort in the morning. Don’t want to miss the MS offer.
3 years for £90. That’s brilliant!
You may run into trouble with 3 years. When you add a 12 month card it gives you the option for an extra month if you turn on automatic billing. You can turn this off again so when you add the next card you get another free month.
If you do add an extra month this way it'll stop you being able to use the third years card as you're only allowed 3 years stacked.
I didn't need it right now (although I can make use of the PC pass) but from my understanding the "convert to ultimate for £1" is a limited deal but happens quite regularly.
So don’t activate the free month then I guess?
Yeah think so. You can decline the extra month.
Cool. Must make sure I do that then.
Hopefully the codes come through before the offer expires.
Hmmm, I have GP Ultimate until Oct 2021... is there anyway I can use this to extend my sub? From what I can tell, applying codes to an existing sub just converts the 12m into 4months of ultimate?
No, you'll have to wait until it expires. Once you have GPU, you're stuck.
Question for people i understand how to buy the code then add with the vpn. I have a microsoft live account that i used with my old xbox account, last used about 2018 time. If i add these codes for the 12m gold live and they go on my account on the brazil site, how do i upgrade for £1 to change it over
Turn on your VPN, go to the Brazilian Xbox site, log in with your normal account and add your live codes. Logout and turn off your VPN.
Log back in to your MS account on the UK site and the £1 offer should be available if you've not used it before.
