So MSI have updated their image to 4+2 on the 3090 cards but not the 3080 cards?
The only site that has the Gaming X Trio 3080 updated is the Polish MSI site weirdly enough...
Here change on MSI website.
So they clearly are aware of issue.
5+1 MLC change to 4+2 MLC
Clearly like evga who said they found out in QC 5+1 wasn't good enough. Maybe this is why there is such a delay in cards.
Maybe they will. Only on specific MSI websites around the world does it show the update Gaming X trio 3080 to 4+2. So maybe they will. If not the ventus is the budget card where as gaming X trio is their flagship card. Hopefully they will for you.Why would they then not also update the Ventus 3x as well?
https://www.msi.com/Graphics-card/GeForce-RTX-3080-VENTUS-3X-10G-OC
Because it has a lower boost?
I love everyone complaining about being 600 ish in the queue I bought mine on 18th and I am 2216 in the queue
Anyone know what the gigabyte gaming oc has got going on in its caps?
I see people say they are 470 a and not the lower number ones, I have no idea what this means6 big fat cheap as chips 'poscaps" ( quotes cause they aren't poscaps technically)
The last I read on the Aorus twitter page was that they were focusing on fulfilling orders for the eagle and gaming OC and didn’t have dates for the Xtreme cards yetshame as I have one on order too. I did speak to a guy at OCUK and he said you’ll be lucky if you see it in Jan and chuckled.
This has been updated, used to be 6 SP Caps.
They're not "cheap as chips" they're different. And besides from what I have seen the gigabyte SPCAPs are better rated than any of the other manufacturers I have seen. Not come across a Giga user reporting crashes yet either, but may have missed them.6 big fat cheap as chips 'poscaps" ( quotes cause they aren't poscaps technically)
Yes, but then you need to work on the authentication. The webshop has that handled, but an outside page connecting to the SQL wouldn't. If they don't have the expertise on-hand to integrate into the existing authentication mechanism then it's suddenly an overkill job just to provide queue positions.
Like I say, I'd like to see some idea of when (or even if, since it's an EVGA) I'm likely to see my 3080. But, to be honest I don't think they should expel THAT much effort unless it's likely to be useful again some time.. Maybe it will and maybe it is. But I'm just saying it might not be the totally easy proposition if it's to be integrated properly.
