***UPDATE 1.5
IMPORTANT INFO
To clarify for everyone and any one new here
the cards affected are as follows re serial number
WK39 onwards will have the revised new connector block *UPDATE however some cards may be mixed and still could be on the old connector block even after WK39
WK38 below is on the old faulty connector block
So check your serial number which will start with year 20 then second number is the week
So 2038 and below would be on old connector block & 2039 and above is on the new one
All the above is confirmed by the Gigabyte Rep
Hope this helps
GeForce Gigabyte RTX 3070 cards Gaming OC and Eagleare not effected by this issue.
There as now been reports of some 3070's Gaming OC having the same problems.
This also effects other cards with the same power connector from Gigabyte i will keep updating
GeForce Gigabyte RTX 3080 Eagle OC
GV-N3080EAGLE OC-10GD
GeForce Gigabyte RTX 3090 Eagle OC
GV-N3090EAGLE OC-24GD
GeForce Gigabyte RTX 3080 Gaming OC
GV-N3080GAMING OC-10GD
GeForce Gigabyte RTX 3090 Gaming OC
GV-N3090GAMING OC-24GD
*add seems these cards are effected also
GeForce Gigabyte RTX 3080 VISION OCThis card is not effected by the issue
GV-N3080VISION OC-10GD
UPDATED images.
This is the old connector block as you can see the the cables are not moulded into the block and only held in via the crimp. Hence with enough force when you plug in your pcie power cables will push out as seen here.
Below is the new connector block as you can see the cables seem to be moulded into the block and there is a another block protruding out of the top block ..this is not seen on the old block above
Here is a photo of the blocks in the card to help you identify which block your on.
Original update on how to visually identify if your on Old or New connector block.
If you have a card that is WK38 and below take a look at the backside of the card and in the vents where the connectors are you will either see heat shrink or no heat shrink on the cables as seen in the photo's below.
No heat shrink means your on the faulty connector block
If there is heat shrink then all good its on the new revised connector block. please see photos below.
If the design changes in the future which gigabyte may revise and stop using the heat shrink on the cable this does not mean it will be on the old faulty block. So any card Wk39 above even without heat shrink will still be fine just to be clear.
So this is on the new revised block as you can see the heat shrink around the cable.
If you see no heat shrink in the gap and your card is Wk39 or below with only a cable tie then its the old faulty design.
Regarding support if your anywhere else in the world other than the UK please contact Gigabyte support via there website they are aware of this issue.
UK OWNERS ONLY.
Please refer to update 3 on how to proceed if you have these problems with the connector.
***UPDATE 2
from Gigabyte rep
***UPDATE 3
from Gigabyte rep
***UPDATE 4
from Gigabyte rep
Original Post..
This as me really worried ....re the eagles strange power connector even der8auer in a recent vid pointed this out link below.
Now we all know what the old Molex connectors can be like i have seen many of them burnt out in builds... hell even seen full burn outs and cause fires and this was just running hard drives cd roms ect . if its not a firm contact this can lead to high resistance within the plug
so will be even more with the amps being pulled with a 3080
Time @9:41
Also user on forums stated the following
"Grimfusion said: ↑
I just RMA'ed my 3080 Gigabyte Eagel OC today. The PCI connector pins looked like they were soldered on in a rush.
3 of the 8 pins in the connector closest to the back of the card are seated much lower than they should be and I suspect that might be a problem when it gets hot.
I ran a couple of games for like 15 minutes before the screen went black and the fans stopped on the card (logo was still illuminated) and I had a black screen.
Plugged my Radeon 7 in and played for hours. PSU is a 750W.
So sad..."
Not trying to scaremonger here ..i have one of these cards myself on order and i am now thinking of cancelling..
your thoughts?
IMPORTANT INFO
Hope this helps
UPDATED images.
UK OWNERS ONLY.
***UPDATE 2
from Gigabyte rep
We have investigated the issues that have been reported and have a solution to fix any cards that have developed lose or faulty power pins. Any customers that have experienced the same power connector problem as reported on this thread, please contact me directly and I will arrange to have the card fixed with a new connector as quickly as possible.
***UPDATE 3
from Gigabyte rep
Any one that start to have these problems on the cards, please contact [email protected] and I'll get it fixed for you, to save time please include name, address, serial number, check number (these are on the box label) and best day for collection. I'll arrange to have the card collected, fixed and shipped back to you ASAP.
Future cards will have the fix, if you do have a card with an issue as there will be a small amount of mixed stock, contact me and I will make sure to get it fixed for you.
***UPDATE 4
from Gigabyte rep
Based on the current info I have, and this is limited to the reports I see here specifically. The connectors are not faulty, however some units after repeat use are developing a problem where the pins become lose and do not make proper connection with the pin outs form the PSU. I will make sure that anyone that has a card with this original connector, can report the problem to me directly or on here and I will make sure it gets fixed for you ASAP.
Original Post..
Time @9:41
"Grimfusion said: ↑
So sad..."
your thoughts?
