I had forgot i had created this thread ![Confused :confused: :confused:](/styles/default/xenforo/vbSmilies/Normal/confused.gif)
must say this re-enforces my belief in these stupid connectors gigabyte have gone for
i knew these where trouble as soon as i set eyes on them
So thx for all the info everybody re this
and sorry you lot having to deal with such a crap design
At the price they are they should not be like this it unacceptable..i am sure they will have to redesign that connector
that's no good i am amazed it did not melt the whole connector
having to change psu to get the connector to fit not good ..i feel lots of peeps are going to have problems with these connectors on there cards..
If it helps i am not paying over £650 to have a rubbish design problem like this so i am either cancelling and just sit a wait till AMD shows there hand or changing to another card one without a rubbish connector design
sry to see this
the money you have spent you should not have to be doing anything like this ..this is a big risk re resistance in power delivery with such high amps and will only get worse the more you re plug in and you run the risk of major damage not to the card itself but the psu hell even fire .... Gigabyte need to address this ASAP very poor design..
I hope you all manage to get things resolved ..i am cancelling for sure now..
this is not on Gigabyte !!
After a long weekend of heavy loads, the card is still working fine. However last time I checked, one of the pins has developed a little molten ball on top. Bit worrying!
I've been in touch with OC technical and they're being very helpful and offered me a replacement, but I'm reluctant untill we get word from Gigabyte as to whether this is normal or just a dodgy batch. It's been passed on to OC management who are looking into the issue. Will keep you updated.
Had same scare with Gaming OC card. I couldnt fit in connectors from Gigabyte psu , Luckily i have old EVGA Supernova 850W G2 and it was perfect fit in. Card works well no crashes on stock settings so far i tested it with Watch Dogs2 and GTA V. I tried manual overclock but it crashes over 2k Mhz. Im sure im not doing it right. Anyway stock boost is 1995Mhz which isnt bad
To be clear i changed whole psu and psu cables not just swap vga cables . Afaik cables from different psu manufacturers may not be compatible i didnt want to risk it
Hey. So i am plan to buy Gigabyte 3090 Gaming Oc. Should i cancel because of that connectors or will be fine?
I have this exact issue, my 3090 Gaming OC doesn't start now. All it took was one unplugging and replugging to tidy up the cabling a bit after the initial testing. Looking at the pins they are definitely all over the place. Not happy, especially since it's such minor thing and easy to get right/wrong, yet so critical. I could try and get those pins in order with some tweezers, but for such an expensive product you wouldn't expect having to resort to such measures. Nor do I want to.
sry to see this
